Turtle Beach x12 Circuit board
I need help with wiring color inside the circuit board. such as red/blue/bronze/green go.
Hubert Lee, just tore one down for a repair. Attached are a few images that might assist you with your wire situation. Hope this helps, good luck.
For some reason I dont have a blue wire but I do have a red and green wire with with blue wire wrapping around it. I am short one wire
In your picture you have 5 wires coming out of that cable I only have four
Dulaga Ferhatovic, yes, that is correct. I just verified this with another headphone. Remove more of your original insulation and see what you get.
You are a legend. Thanks for pic. i kicked red and gold headphone wires out from right ear piece that cross over into left side where circuit board is. it was obvious to me where the red one went but been scratching my head for ages wondering where the gold one went. Then i found your pic. Much appreciated. Saved me some money :)))))))
trevorrutledge, you are welcome:-)
I just fixed my turtle beach XL1. Wires were pulled from the circuit board inside the ear phone.
M+ = White
M- = Green
L = Red
Gnd = copper shield that was wrapped around white wire
R = Blue
If u open up the little box with the chat volume (or where u plug the xbox controller into the headphones) the circuit board in there has the same labels as the board in the headphone. weird thing is, the red, blue, and green on these wires is not the insulation around the wires, but the wires itself. If u try to strip off the color, u will see the inside is just a strength suppling rope or cable that the actual wire wraps around. u just solder the color right to the board. The only wire that has insulation around it that u have to strip is the white wire. Mine work great now......
Whats the connections on the volume circuit board , on the headphone side. I think label is SL SR M and R
@ConarD, check on here for more images that might help you.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 8,682
3 Comments
What help do you need with that? What is it that you need to know?
by oldturkey03
same problem only with XL1 (or P11). any ideas?
by danny
@danny, exactly what problems do you have?
by oldturkey03
