LG Optimus G2 Guide?
Will you guys be covering the disassembly of the new LG Optimus G2 soon or know of any place that already has this information available? I've been searching the net daily for a guide because I'm afraid of ruining any of the phone's internals.
8 Comments
Jeremy, what kind of glue did you use to glue the glass onto the lcd? (and what else if you used anything other than that)
by Saga
The glass was already bonded to the LCD screen in the replacement I bought. If you're referring to how I affixed the replacement screen to the frame, I used 3M mobile tape.
by Jeremy
Hey Jeremy, did the glass replacement on the G2 work out for you? I had heard that the glass was glued to the LCD on the G2 and was difficult to remove. The guides only get you up to point before you remove the glass. Did it come off just with a heat gun?
by Mike
Yes. The one I purchased off eBay worked for me. The glass/LCD is indeed "glued" to the frame with adhesive. This is always the difficult part to remove, when replacing cell phone screens. Luckily, for me, the original screen was already shattered on one corner, so I was able to chip off some glass with my fingers and a small flathead. That created a "hole" on that corner of the phone, and I just used it as leverage to slowly pry the glass around the casing using a plastic knife. I did not use a heatgun or blow dryer this time around, although that usually does make screen removal easier.
by Jeremy
Wait, did you replace just the glass/digitizer and keep the original LCD? This is what I want to do. Or did you replace the LCD/glass/digitizer as a unit? That is a much more expensive part. I think the LCD/glass/digitizer was $150, while the glass/digitizer by itself was $40.
Mike
by Mike
Show 3 more comments
