Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
288 Questions View all
Can a defect I/O board prevent boot?
My MBA is dead. Can't charge. Would not start.
MacBook Air "Core i5" 1.7 13" (Mid-2011)
Can a defect I/O board create this situation? The charger is tested and OK. I have had this situation a week ago. Unplugged the battery and measured the power, seems OK, dismount the I/O cable, and left the Macbook open for 3 hours. After assembling it worked again for a week. Now its dead again. have measured the battery power now its only 2 volts. When trying to charge the battery nothing happens.
No liquids, no bumps - What shall I look fore?
Comments:
Can you give us the last four digits of your serial number so we can correctly ID your system.
by
It's a MocBook Air 13 A1369 mid 2011 - last four digits of serial no. is DJWV
by
Add a comment
Chosen Solution
Peter,
Given your problem I don't think your I/O cable is the problem. The power logic is part of the main logic board. It's more likely you have a bad logic board (cold solder joint).
Score 2
Add a comment
This answer was originally to another question.
Use a multimeter to test the output of the charger. What does the battery test button tell you? Professional serve people have a place in life too. Even they might have a tough time with this one.
Score 1
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 477
