Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
Lower speaker, broken metal pin - why it still works?
Hello fellow fixers! I fixed my phone and accidentally when re-assembling a pin broke for some reason, i wonder does it affect anything? So far everything i can think of works. Is it just a for the structural stability/support?
Add a comment
1 Answer
Chosen Solution
Those pins are for the antenna (where the finger in the photo is placed) so it has wider range as those 4 pins contact the metal edge of the midframe. Any one of those pins making good contact should give you reception. If you repair again, just be very careful not to cause any more damage.
Score 1
Comments:
Thank you for your answer! I still have the broken pin, i was also wondering if i solder it back, but if anyone of those pins are enough for 100% reception, maybe no need to start braking things more :)
by
Add a comment
Add your answer
Mike Safari will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 69
