Doesnt slide to unlock phone
After I changed my screen it wont slide open any message nor will it even read my finger only voice control works. I need help
Marcus, make sure that you double check your work. Make sure that the digitizer cable connector is properly seated, check for any bend contacts. If all that checks out, you most likely have a bad digitizer. Speak to the vendor and ask for a refund, replace the display assembly once more. Here is the guide for it. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 134
