1.6, 1.8, or 2 GHz G5 processor
153 Questions View all
Why does my computer freeze/shudown while watching youtube videos?
while watching youtube videos, the computer will shut down or a black screen will appear. If i press escape several times, it comes back up and returns to the video.
Comments:
How much ram are you running?
by
Could be an issue with the flash plugin. Which browser do you use and is the plugin up to date?
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Go under the Apple in the upper left hand corner to "About this Mac". Please give us the operating system information and the amount of RAM. Then go to www.firefox.com and download their browser. Try using that and see if it still shuts down. If if does, then I need you to open it up via the three screws on the bottom of the frame and examine the capacitors (cans) for corrosion and/or bulging (a major issue with this model series). We'll go from there.
Score 2
Comments:
+ Ralph
by
Add a comment
Nicole, you may wish to setup a Genius Bar appointment at an Apple Store to have them look at this for. The issue could be any number of things. If it is happening during YouTube play back and not while watching other videos it is likely software related. The issue may be fixed by running "Software Update" which is available from the Apple logo in the top left of your screen. You can try a different we browser. For example, if you are using Safari you may wish to download FireFox (as mayer recommended) and try watching the same video again to test if you experience the same symptoms. There could also be corruption in your operating system which may require restoration. Whatever the case may be, backup any documents, pictures, music or movies that are important to you before taking it somewhere for help.
Score 1
Add a comment
I dont know much about computers, so where can I find the RAM info as well as the plug in info?
Add a comment
Add your answer
nicole will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,749
