Trouble soldering on new capacitor to logic board
I am trying to solder on a new capacitor near the CPU. Unfortunately the existing solder will not flow.
Is the board coated in something or is there a trick to these boards? I have a fine tip iron with adjustable temp. Can some one tell me what it need to do to get this done? Thanks.
2 Comments
Peter, you have done this before? You are using flux? You are placing solder on the soldering tip before ?
by oldturkey03
I've soldered before but am still quite new. I haven't used flux on this board, yes I had solder on the tip. I'm just trying my hand as I have a water damaged logic board and this one with the busted cap. I figured I'd have a go replacing the cap but had trouble removing it. I have some lead free flux, will that be sufficient?
by Peter
