What is causing this grey screen to LCD, still displaying to external?
MacBook 13" A1342 Mid-2010
I have just changed a logic board and I get a grey screen displayed on the LCD.
The MacBook still boots and still displays using a Mini-displayport to HDMI adapter.
I have tested with another lvds cable from another machine that is no longer functional (can't double check the cable) and with a new LCD which has the same issue. I did come across a question that indicated the nVidia chip might have lifted a little and some people have had success reflowing the BGA.
I don't want to do this if it is just a cable or connection problem.
Has anyone come across this before and how can I fix it?
Add a comment
1 Answer
Chosen Solution
If the external monitor is working, your video chip is fine. Stick with replacing the cable. Why was the logic board replaced?
Score 2
Someone spilled liquid on it, near the LVDS connector, the IC had chipped somehow. Basically it was dead.
I have a LVDS cable on order but this is just annoying the heck out of me. is it likely to be a bent pin or something?
Most likely a corroded LVDS cable. Patience.
Yes it was LVDS. Not corroded but the pins had been slightly damaged.
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 228
