MacBook Pro Disk Drive is not working
My MacBook Pro accidently took a tumble the other day, and now the cd drive won't read cd's. How much would it cost to fix/repair this problem?
Run Applications->Utilities->System Profiler look under ATA devices. Verify the divice is listed. If it is not the cable is disconnected, damaged or the device may be damaged, only further examination can provide a solution.
If this answer is acceptable please return and mark it.
Good Luck,
N.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 13,516
1 Comment
Need the exact model of your MacBook Pro and size to give you the right directions and part. If the battery is removable on your model, that it out and get the information from inside the compartment
by mayer
