A1304 no back light after LCD cable replacement?
Hello,
I have done a lot of reading on this problem so far and it keeps landing me a possible fuse problem but I am having a problem find the correct fuse that may need to be replaced.
I will give you a little background on how this started for me. I got this Air from a family member and it had broken hinges I replaced all the hinge pieces including the LCD cable. When I powered it on I got a white screen so I though it may be another bad LCD cable because I read that was the common problem. So I purchased another cable and same situation. I was messing around with the cable while the power was on to see if the connection was loose and the screen went black. After that happened I assumed I blew out the driver for the LCD screen on the actual screen. I bought another screen powered the laptop and the screen works again, but no back light now. So after some reading I found out it could be a possible fuse, I got a hold of A1304 wiring diagram and narrowed it down to a few possibilities which I am having trouble finding on the motherboard. My question is could someone help me find the proper fuse I may need to replace so I can get the back light working again. Also if anyone know of any other good possibly solutions besides a fuse that may need to be replaced please let me know.
I have posted pictures and the A1304 wiring diagram, please refer to pages 59-63 in the diagram for the LCD pages.
Please any help is greatly appreciated, I have posted on here before about the same laptop and received good help.
Thanks,
Roy
3 Comments
Any other help out there really need this fixed?
by Roy
What are the last three digits of your serial number? This will help to determine the right logicboard.
by oldturkey03
22E
Hopefully this can help you, help me.
Thanks
by Roy
