Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
Is a screen from a wet phone worth saving?
I have an iphone 4 that got wet and is not working. Can I remove the screen to use as a replacement screen?
Add a comment
1 Answer
Chosen Solution
It's worth a shot I suppose, it depends upon the extent of the water damage, if it was only a tiny amount then the screen may have survived the damage but if it was a little bit more then the screen would have most likely been damaged slightly. You won't really know if it's worth saving until you test it out.
The screen itself would probably still work but it will have visible water damage
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 93
