A unibody aluminum generation of the Mac Mini identifiable by the model number A1347, spanning the Mid 2010 to the currently sold Late 2014 model.
617 Questions View all
One RAM slot dead?
I tried to upgrade the memory of my 2010 mini.
Took the 2 x 1GB out, 2 x 4GB in, restart and just one beep.
Took all out, cross checked, tested a lot of times with various DIMMs.
Finally and that's it: Only the DIMM in the upper slot works. No matter which.
One DIMM in the lower slot - beep. Two DIMMs - beep. One in the upper - chime and start... No matter which DIMM.
I did smc and pvram resets.
I don`t see any faulty contact inside of the slot, there´s no dust or anything else.
I'm worried that I killed somehow the lower slot, but how? And what to do now?
Any tip welcome!
Add a comment
1 Answer
Chosen Solution
You run it with 4GB in the upper slot - which is 2x the RAM you had before. OR, you have to replace the logic board or see if you can find someone who can repair the RAM connector (not a DIY project).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
crisb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 664
