Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
MacBook 5 Beep Sound not booting up.
Hello
my macbook gives a 5 beep sound on booting time and not booting up after this.
its working before suddenly hangup i forcefully shutdown the mac as it is hangged after that this problem occurs please suggest what to do to fix this problem
1 Comment
I checked again and found 3 beep sound is coming. according to mayer
3 beeps = no good banks So what is solution now
by
Add a comment
Chosen Solution
Sounds like you pooched your CPU. Need a new logic board. OR if you dropped this machine before this started you could have knocked the RAM loose if you're hearing a single beep every 5 seconds repeating.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
1 Comment:
Reseat the RAM, replace the RAM.
by
Add a comment
Most Helpful Answer
The beeps are to tell you what's wrong, let us know what you're getting for a possible fix:
1 beep = no RAM installed
2 beeps = incompatible RAM types
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
Score 2
1 Comment:
according to you 3 beeps = no good banks So what is solution now
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,661
