The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
296 Questions View all
Why will my washing machine not agitate?
I have a Kenmore HD 70 Series Model 110 Serial #CC0550858. Whenever I load a load of laundry, small or medium size, it fills, but will not agitate. Any suggestions?
Comments:
110 92586210 kenmore
It's spins and drains but didn't agitate.
The lid switch is working.
What is next to check
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
Drive Block or Bell
If the washer won't agitate the drive block or bell might be worn out or broken. The drive block connects the washer transmission to the agitator, if it's worn out the transmission shaft will still move back and forth but the agitator will either stay still or move slightly.
Door Lock Motor and Switch Assembly
If the washer won't agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Door or Lid Latch Assembly
If the washer won't agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling
If the washer won't agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt
If the washer won't agitate the drive belt might have worn out. Over time the drive belt will fail just from normal use . Replace the belt every two or three years depending on how much the washer is used.
Motor Control Board
If the washer won't agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
U-Joint Kit
If the washer is won't agitate the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Drive Motor
If the washer won't agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged it will have to be replaced.
Stator Assembly
If the washer won't agitate the stator assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Rotor Assembly
If the washer won't agitate the rotor assembly at the back of the washer tub might be bad or damaged. The rotor is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the rotor fails or is damaged the washer might not spin or agitate. Check the rotor for damaged magnets or other defects.
Mine was barely turning last week and was repaired with an Agitator Repair Kit
If the washer won't agitate this agitator repair kit may solve the problem. The kit contains the components that wear out over time. This is a relatively easy repair.
Score 1
Add a comment
it will drain and spin but will not agitate
Update
i want to check the dogs in the agitator i cannot open it up
Add a comment
how do take off the agitator
Add a comment
Most of the time, in my experience , check the simplest things first. The belt might need to be adjusted. The next thing I would check is the lid switch and it's plastic activation tip. Sometimes the switch itself can move out of adjustment. If this is the case use a small wooden dowel or a plastic spoon handle and push down till it you hear a click. Be gentil and try several times. Be sure that the timer has moved to the proper position or nothing will work
Add a comment
Add your answer
Debra Johnson will be eternally grateful.
Past 24 Hours: 21
Past 7 Days: 136
Past 30 Days: 529
All Time: 12,794
