The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
243 Questions View all
Samsung Galaxy S II Skyrocket no reception?
Replaced my Samsung Galaxy S II Skyrocket's charging port without issues. Now there no reception. Is there another step after parts replacement? Maybe one that enables phone to recognize new hardware?
Add a comment
Chosen Solution
There is an antenna inside the device that controls the cellular connection. These are very fragile and usually very short and white. You may need to re seat the connection or replace the cable. Unfortunately the only place I've been able to buy them was from over seas but they are cheap.
On the other hard. If you used your SIM card or activated another phone (with you current number) while you were repairing the device it will flag the device as stolen to the provider and you will need to call to get it re-activated.
Score 1
Sorry for the late response. I tried the SIM first as I had done exactly what you described. However no go. On to the antenna and two more tear downs. I was careful with the antenna initially so maybe the thing wasn't completely connected. Cleaned and reconnected and got bars! Although not stable but there. SO I disconnected again reversed connection and have and is maintaining bars. The new SIM was activated in this phone but is currently being used in the old SG2 but I think it will work on install...I hope. Just have to wait for it to try the install. So, that being said; THANK YOU for such a quick response! You were the only person out of the gazillion sites and question (reworded) that offered a solution. Thanks Again! My husband will be thrilled.
Add a comment
I experienced the same problem with my Samsung S2. I had destroyed the charging port by being careless when charging it which meant my phone would not charge at all; although if I was lucky I would get about 10% charge every day.
To resolve the problem, I bought a cheap charging port flex cable off ebay for about £4.00 which I thought was a bargin. After taking the phone apart (with help from a YouTube video) I replaced the port, turned the phone on and it charged perfectly. Then all of a sudden I lost all signal. I moved around the house, hoping to get the slightest bit of signal but no, nothing. I did a lot of research online as to why this has happened and everyone said it was to do with the antenna cable that runs along the left hand side of the phone so my immediate thought was to buy a new one. I did a factory reset to see if that helped but it did not. As I was desperate, the following day I went into town to see if I could find a shop that sold an antenna wire. I went in shop after shop but nowhere sold what I was looking for. I went into a shop and described my problem to the man behind the counter, and he knew exactly what was wrong. On the flex cable there is "REV" followed by a number, and he told me that if the replacement number is not the same as the original then the phone will have no service.
My original cable was "REV2.3" and my replacement cable was "REV2.2".
Long story short... when replacing the charging port make sure the replacement flex cable has the same REV number as the original otherwise you will have no service. Your problem is not related to the antenna wire.
I hope this helps!
Add a comment
Add your answer
Anne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,075
