Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
I've got reception but calls won't connect.
I've got an issue after replacing the charging dock the phone still gets reception but will not make or receive calls. When you call the phone it will ring through then go to voicemail but the phone doesn't have any response, however it still makes and receives texts. I does show signs of the motherboard being soldered previously as the blue coil/inductor has been replaced with a line of solder and there's also a couple more soldered parts next where the silver plug goes. Any help would be appreciated. Thanks
Add a comment
1 Answer
Chosen Solution
Maybe you did not installed the lower parts of the phone correctly and the antenna wos faulty. RF performance can be affected since the phone fails to connect to certain channels
Score 1
Add a comment
Add your answer
S2i will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 246
