Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3190 Questions View all
Where is temperature sensor on iPhone 5?
Hello. I have new iPhone 5, which was manually damaged (don't ask me how). To make it work again I've replaced lightning connector, battery and now i can turn it on and charge it. But now i constantly see message of Temperature overheating (iPhone needs to cool down before you can use it) and i can not use iPhone (except for emergency calls). iPhone's screen is turning down every 5-8 seconds so i have to turn it back on by pressing Home or Power buttons.
When i connect it to iTunes iPhone begins to sync but never finish it because when screen is turning down the sync stops too and iPhone disappear from iTunes (like when i manually disconnect USB cable)
Probably there is a problem with temperature sensor and i have to replace it too but i can not find it. Please help.
Not sure if it helps but i've lost a metal shield which covers LCD's cables.
anybody? can someone help me to find out where is temperature sensor on iPhone 5?
Add a comment
Chosen Solution
There are five of them. One is in the battery, the rest are in several locations
R108 is at almost top of the board, test point XW9
R110 is beside the main camera connector, test point XW11
R57 is beside the A6 chip, test point XW15
R90 is at the bottom back of the board, beside an RF PA, test point XW33
All test points are beneath the SIM slot, check if anything is stuck between them to short anything out
All sensors are 0201 components, they are extremely small, almost impossible to work on
Look for board layout print on the internet to locate the parts
Score 3
many thanks. you gave me direction. i'll try to find out.
Add a comment
Check this out!
Score -1
Add a comment
Add your answer
Oleg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 92
All Time: 12,181
