Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2920 Questions View all
My wifi on my iPhone 4s is greyed what can I do?
I dropped my phone & the wifi stopped working,and then i put it into the freezer. It worked for a good hour & then it stopped. What can i do? please help thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Stella, sounds like you will have to disassemble your phone "then i put it into the freezer. It worked " means that you have a component that has a cracked solder connection. I would suggest to take a good look at it, check the inductors and may be reflow the WiFi IC. Follow this guide to get to your logic board. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
stella will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 132
