1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
256 Questions View all
Does the iMac Intel 17" front bezel include a glass panel?
My iMac Intel 17" suffered a blow to the display area, which cracked a glass panel over the display. It still functions, but looks funky. Do I need to replace just the bezel, or the whole display assembly?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
The bezel does not have the cover glass mounted in it. The glass is part of the display assembly.
But! You maybe able to locate a cover glass off of eBay or even getting a local glass outfit to cut you a piece, then with care dissect the assembly and replace the glass alone.
Place some packing tape across the glass to hold it together before you start.
Add a comment
Add your answer
Klieb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
