Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
513 Questions View all
Sticking track pad button
is this trick valid for Macbook Unibody (white) too? Reference to this question Trackpad click button is jammed
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
I don't recommend the WD-40 trick as it will only make a mess. The oil in it will act like a magnet collecting the dust and debris around your system.
While its some work you can take the track pad out and clean it properly and make sure it's OK (and if needed carefully lube the pivot-point).
The root issue is something either is jamming it or something was spilled onto the click button.
Lastly, the battery could have swelled-up pushing on the trackpad from below.
Add a comment
Add your answer
visoyah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
