Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
285 Questions View all
recycle old laptop display
Hi, I have an old Compaq laptop, which died recently. The two hinges broke so the display completely separated from the body.
The laptop was a piece of junk but the dvi display is still very nice. I am wondering how I can recycle it, make it into a external monitor.
The main thing I need to know is, are the connector wirings pretty standard on all laptops? Where can I find a schematic diagram, would be nice if iFixIt make a adaptor.
TIA
Add a comment
Free shipping on orders over $20
Use code BLUEANDBLACK at checkout
Chosen Solution
If were only so simple ;-{
There are just to many different inter-connection types as well as sizes that would make it very hard to make such a adapter.
Frankly, the cost of a cheap LCD TV which has a VGA or DVI connection is just cheaper in the long haul.
Score 1
Add a comment
rich1812, lets start with this:-) What is the number on the back of the LCD (manufacturer or model number)? Armed with that, you can look for a datasheet and see what other devices uses that model LCD. You will most likely need an inverter circuit, a video circuit and a driver circuit. There are universal LCD Display driver controller boards out, that may help you to convert a display to a monitor. I purchased one through an online auction a couple of years ago, for something like $30, and it worked for me. Check on something like this.
Comments:
Thanks all for the reply.
Actually it seems easier than I thought. After some Googleing, I found this link, precisely what I need! It will be a good weekend project :)
http://www.instructables.com/id/How-to-C...
by
Like I said, all you need is a controller board:-) just like it is mentioned in your link at instructables.com Best of luck to you.
by
Add a comment
Add your answer
rich1812 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 167
