Gray lines on LCD after screen replacement, now iPad wont power
I cracked the screen of my 4th gen iPad and decided to attempt the repair myself. After a good 2 hours of painstakingly removing the shards of screen I finally connected the replacement and decided to test it before completely reassembling. When I first powered on there was grey lines running across the screen so I powered off and rechecked the digitizer and LCD connections - all looked fine. Powered on again, same thing happened. Disconnected LCD and digitizer a second time and tried again. Now my iPad wont power on at all. I've tried a forced reset by holding down the power and home buttons, nothing. It seems totally dead. Tried to restore from itunes but due to the new iOS 7 upgrade, I need to first disable Find iPhone on the iPad - can't get in to the iPad to do so. iTunes at least recognizes the iPad and find iPhone says that my battery is still at 57% so its definitely not an issue with charge. Not sure what the exact problem is and would really appreciate some help on what to try next. I'm guessing I accidentally damaged the LCD and I will order a replacement but given that the screen lit up to begin with and is now unresponsive I fear I have caused some other damage? Thanks in advance for your help.
3 Comments
UPDATE 9/26
New LCD arrived and I connected it up. Nothing. Deflated, I sat the iPad to one side for a couple of hours. I decided to try completely disconnecting the logic board and reinstalling. SUCCESS!! I almost cried when I saw that beautiful white apple logo. Now I just need to install a new home button flex ribbon and I should be all set! :-)
by lsmcmenemy
having the same issue succesfuly screen replacement tried hard reset apple logo appears as white bar across the entire screen, then boots to a light coloured screen made of lines. think its the ribbon cable not connected completely but it doesnt want to do into the connector any further. how do i disconnect the logic board??
by bystand3r
Ok, so I dropped my I pad mini. And it looks like I broke the inside of the screen cause there is a hardly noticeable green line at the corner of the I pad. I also have this flickering bar on the side of my I pad which is making the lighting of my I pad really dim and I can hardly see. How do I fix this, do I need to take apart the I pad mini?
by Anonymous
