Cheapest way to install windows with broken optical drive?
My optical drive is broken, and the replacement drive is ~170$. I don't ever use an optical drive, but seemingly need one to install windows on my old(er) mbp as bootcamp does not have an install via usb option for these antiquated devices.
I was thinking of purchasing an external optical drive for occasional/rare usage. Can anyone suggest one that would work with my late 2008 15" mbp, or a way to work around not having an optical drive with bootcamp?
Thank you in advance
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
You should be able to find a unit for around $60 (us), even new! Which is still cheaper than an USB external drive.
Are you sure your drive is dead? Often a good CD/DVD head cleaning disk (a can of can'ed air) can do wonders.
As to installing Windows you should be able to use another systems CD/DVD player as a network resource to access the installer files.
Score 1
Comments:
I have seen the new external superdrives on the apple website for around 60 bucks, but they aren't compatible with my mbp. Maybe you could give me a link to what you're referring to?
The drive isn't dead, I just took it out of the body today and cleaned it. When I put in the windows disk it read it ask blank media. Other disks it simply spits out.
I have never heard of being able to use another computers hardware to install onto my own computer? There are no other macs in the house or nearby. Is there a tutorial on how to do this (does google search)?
Thank you for your response!
by
If it's not dead (you can read a music CD or data CD) then your media the Windows is on is not compatible with your current drive. A newer version of the drive that can be used in your system is the way to go here. As to where to find them I just googled it. I'll post a few here for you tomorrow. As to sharing you can setup either a PC (Windows or LINUX) or a Mac (OS-X or LINUX) as a network share. But you need to have a network setup either Ethernet or WiFi.
by
I appreciate the help. I was able to use a PC and a windows disk to make an ISO image and modify my bootcamp to allow me to make a USB boot drive. Up and running! Thanks for your help.
by
Thats great news! If this answer was helpful please remember to score it and mark it accepted.
by
Add a comment
Add your answer
Jeff will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 932
