Repair guides for the MacBook Air, Apple's current line of consumer laptops.
2439 Questions View all
How to move data from my old hard disk to my new one?
I took out my HD from my Mac air, is there anyway to move the data from it onto another computer? I took it out because it had an error code: 4hdd/11/40000000 SATA (0,0).
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
That is a hardware error code, it could be the cable or the drive. Get an external case for your drive (some new/replacement MacBookAir drives can be purchased with an external case for the original drive) If it's not damage to the the dive it will mount (if it mounts you may need a new SATA cable for the MacBookAir). From the New OS install you should be able to use Migration assistant to transfer the files... OR use TimeCapsule to restore from your old backup.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
Raymundo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 233
