Doesn't boot, only the chiming sound and it freezes.
My MBP doesn't boot. I can hear the chime, it starts to load OSX, but after about 10-15 seconds it freezes.
When i try to boot in Safe boot mode, it works well.
I've tried to reinstall the system from an usb pendrive and from an install dvd also, but i experienced the same like when i try to boot normally. ( Chime, apple logo, and it freezes after 10-15 seconds )
In verbose mode i didn't see any kernel panic, the loading stops in various operations.
Does anyone have an idea what could be the problem?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Sounds like disk failure or OS corruption. Boot from a repair disk and run DiskTools->Disk First Aid:repair disk, and repair permissions. You could run AHT 2 or 3 times to see if it detects an error (often running AHT only once finds nothing wrong).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Comments:
Here is what i did until now:
-SMC reset
-NVRAM reset
-I formatted the HDD in an other mac, the disk seems to be ok.
-I am unable to run AHT ( Nothing happens if i push the D button )
-when i try to boot from an osx install dvd or a repair disk, it freezes again during boot.
by
THat might be a bad Optical Drive... can you boot to an external HD with an OS on it or from a Target Booted other Mac?
by
Add a comment
Add your answer
revengangel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 209
