The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
34 Questions View all
My Phone is dead, now it is not powering on.
I tried to charge my battery of my nexus s from another local charger. . . but it made my phone dead.
when i check supply pins of phone when positive and negative of battery comes in contact with device's pin with my external power supply and power it on. .
it doesn't power on. .
I took my cellphone to repairers to get it checked. they told me it's problem of power ic
I myself is a electronics engineer. so please guide me it is exact problem of power ic or something else. .
Hope, my post will be seriously taken into consideration.
Score 2
Comments:
i have this problem too..if u have any solution so plzz tell me....
thnkxx!!!!
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
If your power IC is dead then you'd have to either replace the entire board or become a robot and solder on a new one. HOWEVER, try this: take out your battery, put it back in, hold both volume down+volume up and plug in a USB cable. If your phone boots into download mode then all is not lost! Here is a new motherboard if you're intent on fixing this phone (provided it is a Sprint Nexus S), or swappa has a phenomenal array of smartphones for cheap.
Cheers,
tabormeister
Add a comment
chake this
https://www.facebook.com/pages/Dead-sams...
Add a comment
same happened with my phone i did what you said not working
Add a comment
Add your answer
Subhash will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,709
