1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
268 Questions View all
Why is the loading taking so long?
When loading a file from documents or going on gmail, it takes forever to load.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Start up holding down the Command and R keys. Run Disk Utilities and see if the drive needs repair.
Score 1
Add a comment
Most Helpful Answer
Check your HD for corruption. AHT ->Tools->Disk Tools: repair disk, repair permissions... if you can't do those then your Flash Drive may be bad.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Can you let know if its happening regularly or randomly? You said when you go to gmail, mean the file may be very large to load or internet speed may not be good enough to upload the file to gmail. However, if your hard drive is acting strange and disk utility confirm damages then try to back up most data to an external hard drive or else download a 3rd party Mac utility to repair your HDD. I can suggest you try the following
http://www.stellarinfo.com/mac-software/...
http://www.alsoft.com/diskwarrior/
http://www.micromat.com/
Regards
Score 1
Add a comment
Add your answer
hayeem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 112
