Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
LCD wont light up, or the apple light icon on display cover?
doesnt seem to hold charge i can hear the fans hard drive & DVD power up Disc will eject,no display light on cover or LCD
Score -1
Add a comment
Chosen Solution
Try to connect the MacBook to an external monitor and check if you get video on the external. If so then you have a screen problem, if not then the logic board might be affected. Looks like a liquid spilled unit ???
Score 2
Add a comment
Could be a dead inverter board or faulty cable / loose connection. Did you drop the MB?
Score 1
Add a comment
I had this behavior mostly from fluid damaged MacBooks - but there are many possibilities - the only way to rule a fluid damage out is to open the MacBook
Add a comment
Add your answer
shonta burley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 741
