A Samsung Galaxy S phone for the South Korean market identifiable by the model number SHW-M110S, released in 2010.
2 Questions View all
Google Play Store cannot be able to establish a reliable connecti
I have a samsung galaxy s but not the original one. it is samsung anycall galaxy s (Model # SHW-110S) the korean copy of samung galaxy s. i had problems with its messaging limit only 80 bytes per message and that was awful. so i got a new firmware installed in it by a local electronics shop. Now the details are as follows:
-Firmware version: 2.3.6
-Baseband version: M110S.WA03.0942.ST
-Kernel Version: 2.6.35.7
-Build number: GFAN_M110S_GINGERBREAD.WC13_FTE9K_ODEX_SP4
[*hope this helps*]
And from that day, i am unable to access/sign-in/sign-up or even use the google play store. whenever i try to sign into google play store or youtube, an error message appears saying that google cannot establish a reliable data connection to its server.
i need your help immidiately and i will be very thanfull to you. please suggest me a new and suitable firmware to install and please suggest me a link to download that particular firmware.
THANKS IN ADVANCE.
Score 5
1 Comment
what if my phone reboot it can be korean language ?
by
Add a comment
Chosen Solution
WARNING: YOU MAY LOSE ALL YOUR DATA BY DOING THIS.
Issues:
- Account sync OFF permanently with the message: "Sync is currently experiencing problems".
- Signing in Google Apps fails showing message: "Can't establish a reliable connection to the server"
Possible Cause:
- system file named 'hosts' (/etc/hosts) points to a Google server that changed IP, thus blocking access to Apps.
Possible Solution:
- edit 'hosts' file (/etc/hosts) deleting or commenting (adding a # at the beginning) the old line
I have a Samsung Galaxy S AnyCall M110S with GFAN WF07 SP 8 XDA Version i tested it and it worked...
It may be work on any android device.
Please do it at your own risk.
How to do it:
METHOD 1
1.- Root your device (of course)
2.- Editing the file
You will need a proper editor
On your device open your browser and go to: www.ghisler.com/android.htm
Download and Install Total Commander for Android... and open it
OR DOWNLOAD BELOW
3.- Browse with Total Commander to root/etc
(hint: on the right side of the screen there's a shortcut to system folder.. look for etc/ and you will find it)
Long tap on "hosts" > edit file > Totalcmd-Editor
Open etc/hosts and edit the file. Just put # before 74.125.93.113 android.clients.google.com.
4.- SAVED
Edited file should look like this:
127.0.0.1 localhost
#74.125.93.113 android.clients.google.com
remember: based on my own observation it should be look like this:
127.0.0.1(just one space)localhost
#74.125.93.113(just one space)android.clients.google.com
5.- Turn OFF your device.
6.- Got it on Recovery Mode
7.- Factory reset, wipe data.
8. Reboot your device.
9. Once the phone reboots, input your google account information when the phone asks for it.
10.- Sync to your account and contacts
METHOD 2:
1. Make sure you have a ROOT ACCESS on your Device.
2. Install Root Explorer, Run App, Grant SU Access.
3. Browse root / etc... at the top of your screen you will see mount R/O and mount R/W...
4.Tap mount R/W
5.Look for host file, long press it and open with text editor.
6. just Add # (pound sign) on the first number.
like this:
SAVE IT and Reboot.
Now you can connect to Google Play very well.
Score 48
77 Comments:
I love you shinta098 , you just solved my problem!! I just don't know how to thank you.....
Just love iFixit
by
wow itz wrkng thkz frnd :)
by
bro iove you man words can`t describe how happy iam dude you are the best
by
My pleasure guys!
by
an easy way to get rid out of this message "can't establish a reliable connection to the server etc" is to go to settings to your phone ->Security ->Device Administrations -> activate Android Device Manager
by
Show 72 more comments
Add a comment
My google play store can"t work
Add a comment
Add your answer
hasso will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 9,825
