Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
301 Questions View all
Refitting bezel after removal with heat gun
I am replacing the LCD on a MacBook Pro mid 2009, anti glare version. this is the one with the grey bezel around, that is glued on, that needs to be removed with a heat gun. I am nearly ready to start with my special IFixit toolkit, but have one question.....
One of the IFixit guides (the first one) indicates that the adhesive remnants should be cleaned off with isopropyl alchohol and then 3M VHB 4905 tape used to fix the bezel back on. The latest guide does not mention this.
So do I need to re-adhere? And if I do, is there an alternative to 3M VHB 4905? So far I can only find that tape for £100 a roll!
Thanks, Simon
Comments:
Boy the tape is worth more than gold in the UK ;-{ 100 Pounds Ouch!
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
What you need is a thin double adhesive tape that doesn't dry out and is not permanent. Check out a local crafts/hobby store to see if they have something like photo mount tape. Of course you could order it from IFIXIT Adhesive Strips which will work here as well (will need to cut them down a bit).
iPad Adhesive Strips Image
Product
$9.99
Score 2
Add a comment
Add your answer
Simon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 184
