Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
516 Questions View all
If I do a SMC reset, then the battery will charge.
I am having a very similar problem.
If I don't do a reset and the computer gets turned off or the adapter comes out of the MagSafe, then it will not charge.
The computer will run on battery only as long as it has power remaining.
If either of us figure out the problem, we should tell the other.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Your problem might be different just very similar. Check your date & time settings after restarting your system (make sure you'er not connected to the internet for this test from the get go). If your settings are off your PRAM battery needs to be replaced Replacing MacBook Core Duo PRAM Battery. I've seen some odd problems when the battery is low or failing.
Score 1
Add a comment
Add your answer
Russ Wyborski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 118
