Major spill damage on the keyboard
@ all spill secialists: Im working on a MBP 13" 1278 after it got in contact with a big pot o' tea an' honey whilst running.
Having it dissembled, dried, cleaned, contactsprayed, andsoforth, I found the mainboard is o.k. , trackpad & screen are working fine, but 4/5 of the keys including the on/off button are not functioning.
It can be started by disconecting the battery for 10 sec., then plugging in the charger ( short circuit ?! )
Is there any other way to get the MPB in working order, than replacing the topcase ?
Greetings from Krautland
2 Comments
@ Stone ! Thanx for the hint. But how am I going solve that ƒ¨ç∆⁄~© on/off button problem ?
by Alexander deLarge
As I said - there are two possibilities: first is to exchange the keyboard which is perfectly described in one of the guides here on IFIXIT, second is to shorten the switch just like you do it when you press it (you need to look up, which contacts / solder lines need to be shorten ... it is a little bit more difficult).
Regards, Stone
by Stone
