Acer Aspire One A0751h laptop.
8 Questions View all
Computer crashes (freezes) randomly.
The A0751h has a sort-of known crashing problem. It seems to randomly freeze. Becoming 100% unresponsive, video is stuck on whatever image was before the freeze, the sound sounds like a broken record. There is no BSOD and it has been known to happen in the same way in linux.
Updating the firmware to the latest version provided by acer helps a bit since the freezing is down to once every couple of days vs once every couple of hrs (or more frequent).
So the question is: Does anyone know if this is a hardware issue, and what sort of fixes (including changing parts) will fix it.
Still gathering info. The most useful lead is the replacing of the ram seems to help. Still need to confirm AND get some model numbers for known ram that fixes the issue.
Score 8
Comments:
Acer is the number one laptop i fix daily, so many of them go wrong. The flickering screen, nosey fans, random crashs. If you fix yours get rid of it quickly.
SPAM
by
I have an Acer Aspire One A0751h, 2BB RAM, 220 GB HD, running Vista Home Basic. I've been very disappointed with the frequent freezes since I bought it last year. I would have expected better from a major company like Acer. It's the last Acer product I will ever buy.
by
Okay lets do it. lets make it a comment ;-)
by
I switched my OS from Windows to ubuntu and have not had a problem at all.
Windows is known to be %@^@ on comps with small memory and/or ram capacities, if you don't know how or can't afford to change parts ubuntu is free, it takes a bit to learn how to use but I found it was well worth it.
by
Mine, Acer ES1-711 Model: ZYL, is reproducible by any heavy video activity especially 100% failure with full screen. I don't get the sound. My previous laptop, AMD based, lasted 10 yrs on linux. This one is going to be chucked as I have found no solution in the last year. Disappointing. My guess is the atom chip which handles the video is the culprit.
by
Show 10 more comments
Add a comment
Chosen Solution
Look i had the same problem.My netbook froze,so i had to hard reset it.After this kept happening for about six months,one day i turned it on, and i pressed start windows normally(I use win7). Then, in the screen starting windows,the graphics went crazy.Safe mode:the same. I changed ram,it start ok but the freeze wasnt fixed.A friend of mine gave me his netbook to compare.Changed the hard drives.My hardrive in his netbook gave no freeze and i havent turned it off for about 3 months.So it isn't de hardrive either. So i can say it isn't software,but hardware.And the only thing that can freeze screen and sound at the same time is graphics and sound card,wich are both on the motherboard. I changed motherboard and everything was fine. Not sure if it's the same on all aspire ones but i hope this will fixit.
Hope this helped!
Score 6
Comments:
It appears that the problem is the motherboard. I actually expected the RAM to be the problem, but looks like you pretty much proved that the mobo is the cause. If you replace the mobo feels like you might as well get a new computer. Question: What mobo did you buy and where/price. Are there any better mobos to buy? Like one with a better graphics card which is supported by linux.
by
@Dmitriy, I live in greece,so i just bought one with the basic features. I got the mobo with 150 euros, and a new ram with 25 euros.I asked a friend to find me one,cause he runs an electronics shop,so im not so sure where he got it. I will ask him and reply as soon as possible. And i will search for better motherboards with more features in google.
by
Well,he got it directly from acer. Now,about more mobos,i couldn't find somewere to buy.Only tutorials on how to replace it.Serch e-bay,or go to an electr. shop. Hope you have more luck.
by
my laptop on acer aspire one on windows 10 it is keep saying your pc crashed
by
I was right! The Graphics Card was broken! Thanks, this was very helpful!
by
Show 1 more comment
Add a comment
Most Helpful Answer
Hi, Apparently this is a design flaw in that unit. I am including just one of many discussions and cussing about this unit. There is according to one poster a key combination that resets things for a time but Acer is not passing it to end users. Based on what I read if you can return the unit you might want to consider it. Good luck Ralph
http://www.complaintsboard.com/complaint...
Score 6
Comments:
I remember before the BIOS upgrades that the computer would not even boot after such a crash, I had to pull the battery. Now it can just be reset by holding the power button down until it just shuts off. I am quite disappointed that I cannot return it anymore.
by
Add a comment
Returned system to Acer 3x now. still same problem.FREEZES. Win7 installed. added HDD inspector for HDD temp. removed HDD cover, 6"fan directly on system, unit raised 1.25" with plastic raiser.
this was to allow only 4 Auto updates. HDD temp 90*, this time all updates passed. next will attempt Office 2010 Pro Full install, with same method. normal install has failed 3 times.
Retired computer-elec tech. many thing to try... will keep posting back.
Snuffy
Update
Today ran some tests. removed memory cover, removed hdd cover,using usb - started installation of Office-2010 Pro. monitored HDD temp, max - 102 no enough to kill. installation went 100%. replaced HDD cover & still again repair installation 100%. so far i see the backing over the memory cover does not allow heat removal. I'll remove the hard backing & replace with cloth...
Update
1. It is 100% clean of Virus - guaranteed
2. power supply is quite big - no problem there
3. I use the WORK METHOD to test for FREEZE UP. insert a USB and either CLEAN install Office(full)SP1(1.21GB) or DL massive upgrades from MS... before removal of heat shield from MEMORY i could FREEZE very easy.. from 1983 to day 99% for me FREEZE is memory or CPU heat problem. test has been working CPU Memory and HDDs - hince UPDATE or DL at max - monitor is easy to see if working hard.
removal of cover - now can DL over 4GB max NoProblem, Installed Office 2010 - NoProblem, 1st time HDD ever went to 110* w/o freeze.
There are NO ACCESSORIES on this UNIT.
Update
I think I have found the fix - open display and change to Win7 Basic.
a. Memtestx86 over 9 hrs - NO ERRORS
b. WD Diag HDD and ALL TESTS - PASS.
c. opened Display and changed theme to Win7 Basic .. No more errors, today. no fans used, plenty of heat... HDD temp over 112*, memory warm to touch. NO ERRORS...
Update
Sounds normal. I finally disabled AERO. No Freeze up since.
Thanks to all the others whom have offered. Take the Battery out , changed PWR Supply, swapped memory swapped HDDS. the only thing I have to do is DISABLE AERO. then NO FREEZES but the sound is distorted.(I can live with that.)
Score 5
Comments:
Removed hard \backing from memory cover. replaced.
have ran several very heavy program. DL 1 1.3 GB file, HDD temp to 110*, No FREEZE, simply working fine. Memory heat problem fixed. do recommend you glue a very thin porus cloth over holes in Memory cover. tests ran for over 3hrs NO FREEZES.
by
The thing is, I've never been successfully able to reproduce the problem consistently. It can work fine for weeks, and freeze every 30 minutes at other times.
Generally motherboards kill the power if overheating, they dont just freeze up everything. And when frozen it did not seem to be at extreme temperatures.
Ive heard that replacing the ram fixes the problem, but without a consistent reproduction scenario determining what component is at fault, I have no idea how to confirm.
by
The freezes on the Netbook(s) by Acer has also been found on many of the other netbooks... the problem has been found an fixed by M$ whom noted that they had a problem in the software... you can find the fix there. Look on the M$ site for Freezefix. (Its not Acer(s) problem. it was M$ software problem....
by
OK, finally the 2GB Samsung memory chip blew. I replaced with a TOTALLY different name brand chip. and for 3 days very heavy use. doing everything that use to FAIL (make FREEZE) and its rock solid.
I recommend checking to see if your memory chip is SAMSUNG.. if yes,
replace it...WOW what a nice feeling... NO FREEZE..
by
Seems like a very common response. Change ram it works great. Snuffy, if you can get back to this post in say... 2 weeks and report if it ever froze in the same way again, it would be much appreciated.
by
Show 2 more comments
Add a comment
when a computer gets slow it is a pain and i know how that feels so what we can do to fix this issue try these simple steps -
1-just remove all unwanted startup programs they slow down the computer boot
2-remove all unwanted software using any software remover tool like revo uninstaller
3. check the computer R.A.M if possible please change or upgrade it .
4- for windows 10 or windows 8 user i would say visit https://www.speedupacer.com/
Open Start Menu and find the Control Panel. Click on it.
Here in the Control Panel, go to the Search field at the top-right of the window and type Performance. Now hit Enter.
Now find Adjust the appearance and performance of Windows.
Go to the Advanced tab and click on Change in the Virtual Memory section.
Now untick the option “Automatically manage paging file size for all drives.”
Select the default C: drive where Windows 10 is installed and then choose Custom Size. Then change Initial Size and Maximum Size to the recommended values by Window . lets see if this works and solves the problem
Score 4
Comments:
no need to remove any program.
1. disable in startup-if you need you can manual start any time.
2. Remove all unwanted - Revo is excellent choice. *my preference" but cost,
you can try a FREE IOBits Uninstaller, they also have a nice program (FREE) Advanced SystemCare. that works pretty good.
by
Add a comment
Dmitriy, if you have a utility to check memory and hard disk health, maybe you could find the problem (because of the noise, the hard disk is the most probable problem).
Score 2
Comments:
Already been tried, nothing wrong with HDD or RAM when doing checks. I used a linux boot USB to do a RAM check, and used windows for hard drive check.
by
Add a comment
There are different steps you can take to fix your computer after it has been frozen. If your computer freezes while you’re running an application, but your mouse is still operation, you should press CTRL + ALT + DEL. This will bring up your task manager. Go to the application that is frozen and forcibly shut it down.
In the event that your computer is locked completely and it doesn’t respond at all, even when you do the above, then you should hold down the power button and perform a manual shut down on your computer. You should note that any unsaved data that you may have had before the shutdown will be lost. It’s always important to automatically save or back up your data in case of an emergency.
The final fix to your computer crash should only be done as a last resort. Your computer may have had an important system file deleted or corrupted beyond repair. In this case the only thing you can do is a system restore.
A system restore will essentially reset your computer operating system to the way it was a few weeks or even months ago. You can set it back to a time when the computer was running smoothly. Note that anything that you created or downloaded before the system restore will be lost forever, so backup any important files.
Score 2
Add a comment
If anyone is still interested in knowing the root problem...its the battery....
With the battery in and plugged in to the AC will cause it to freeze randomly.
I tested by removing the battery and then booted up with AC power only. It ran for days until I got bored trying to crash it. ..
Within minutes of plugging the battery back in and clicking on some icons on the desktop...it locked back up instantly....
Retested several times... Theory was correct!
Tried to find a way to contact ACER without being charged...and couldn't get through without having to pay....
Maybe someone out there can amp this up a notch....as I'm sure ACER won't admit to it first hand...to costly for them of course...
Try it an d find out for yourself...
Ed H.
CISA, CRISC, CTGA
Score 1
Comments:
Thank you for this.I removed the battery and it worked.
by
By the way I have an acer aspire one d257.
by
Add a comment
My aspire one had random freeze problems since it was new. Then it would need a wifi connection repair ever few minutes. Then the buttons in a program would stop responding followed soon by a cursor freeze and then a total freeze. All the testing software for memory, cpu and hard drive came up good.
I replaced the hard drive and motherboard and fixed all the problems. Total cost $60 in parts.
Good luck with yours.
Score 1
Comments:
most members here are not computer techy to replace mobos. glad you are.
by
Add a comment
There can be many causes for this.
Hardware
2 most common causes.
Ram
Pull the ram out clean the contacts with denatured Alcohol and reinstall
Power supply dieing or undersized
Remove the accessory from your computer see it that helps otherwise replace.
Software
any number of viruses or spy ware could cause this.
possible solutions.
run antiviras or antispyware programs
Add a comment
im a novice but i think its the battery conection area on the side where it lock take off battery and leave plugged in it wont freeze
Add a comment
Could be memory problem.
Download and run Memtest86+, test the memory module. Make sure it runs multiple passes.
There is only one memory slot on the bottom.
Disassembly guide for Acer Aspire One A0751h netbook .
Comments:
I have ran memtest so many times & for such a long time I was 100% sure the MEMORY was OK...but as soon as you started almost anything it FROZE, replaced the Samsung memory & NO MORE FREEZES...
PS: Nice take apart guide...
by
Add a comment
FOR all users that have problems with the wifi connect freezing the netbook after 1 minute====
ENABLE NETWORK BOOT IN BIOS!!! (worked for me on ubuntu 64 bit 11.04)
Add a comment
After replacing the Memory with a NEW Non Samsung Chip. Computer started with NO problems, I also got a new clean install....
Never had another Problem.... never froze, works perfect.... so nice my neighbor bought it for his GrandDaughter, who uses it every day and
Seen GrandDad this AM.... says the little Acer is so nice he also bought his Wife a New Acer for Christmas because the A0751 worked so nice.
Reference to the battery problem... by ehustus . M$ has admitted that they had a BAD and have offered a Battery Fix which reportedly has cured over 95% of all Battery Problems with all systems...
Add a comment
I own 3 Acer Aspire AO751h netbooks, and have experienced freezing from time to time, although not as severely some have. My netbooks will freeze mostly coming out of standby or sleep, and occasionally recovering from hiberation. I am running Windows XP and double booting with Linux Mint V 9, 10, 11 respectively. I tried changing hard drives, booting from external drives, different operating systems and changing RAM. What I learned was, virtually all Linux distros had less freezing, KDE and XFCE had better controls of the variables---much less freezing, and (''Here's the SOL
OUTION!) changing the video driver in Linux to the GMA500 Poulsbo driver virtually stopped all of the freezing.'' The GMA500 driver is installed through Synaptic Package Manager after adding the repository:" http://ppa.launchpad.net/gma500/ppa/ubun... maverick main" to the Software sources. I love my little 11.6" Acer netbooks! They just need the right software to take advantage of them.
Add a comment
You know netbook is netbook, not a laptop or desktop pc, adding or upgrading hardware is an option but not the most effective way to fix freezes issues. The fact is you should do regular system maintenance job such as disable startup programs you don't use in the control panel , disk defragment, disk cleaning, remove any programs you no longer want, clean those unneeded files to free disk space etc.
Learn more:
Fix Acer Laptop Freezes Issue
PCWorld - Speed up Windows XP Netbook
Add a comment
I think why your laptop freezes is that there too many programs that are opened at the same time, you can try to defrag your laptop. Anyway try to check your RAM if still have spaces,
And also other reasons why your laptop freeze is that there are progrmas that are not properly installed/
Add a comment
I think I found the cause and I am pretty sure it is hardware [CPU MoBo] related. I installed a PC benchmark program and this caused the CPU to hit the 100% and that immediately freezes the system. With the task manager you can see it really clear.
Funny thing is that I have the same laptop as my daughter and only on my Daughters the problem occurs. I had already tried everything to solve it software wise, but without any luck.
When I saw the 100% result into a crash I knew this was hardware related. Sent the module back to my shop, within two weeks I will be notified.
Add a comment
i have one of these acer netbooks.It crashed a lot.but i found how can be repaired.
I have windows xp. Go to control panel.click system.then go to advanced.then on performance part, click settings.then go to advanced.then in memory useage, select system cache.
ok all of the windows.
Iam sure it work.
Add a comment
I installeer a New harddrive ssd and The Problem was Fixed!
Add a comment
Add your answer
Dmitriy Likhten will be eternally grateful.
Past 24 Hours: 39
Past 7 Days: 259
Past 30 Days: 1,328
All Time: 124,854
