Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3251 Questions View all
I installed a replacement iPhone 4 screen. I bent the lcd cable.
When I repaired my iphone 4 (gsm) it was all going well until I put the screen back on. In haste, I bent the lcd cable. I thought nothing of it. After I had put it back together it worked fine, apart from the lcd having dim lines on the screen where icons or writing were. It is not a big problem, I can live with it. But it would be nice to know if I can fix it by bending the cable back.
Add a comment
Free shipping on orders over $20
Use code BLUEANDBLACK at checkout
1 Answer
Chosen Solution
Damaged flex cable is impossible to repair. I almost damaged one today too, close call
Comments:
Can you bend it slowly around a screwdriver?
by
Add a comment
Add your answer
fscottcopeland will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 367
