Does this microwave have a fuse
Panasonic Microwave model # NN-H964WF went to use microwave , it came on and shut right back off , this is why i think it might be the fuse , also where is it located inside
Bruce, yes it does have a fuse. You may have to either take the housing off or remove the back. It is located next to the noise filter PCB, near the fan. Remember those things have a bite to it, so you do need to make sure that you take proper precaution. Part number for the fuse is F62308F00Ap and it is available at places like this as well as many more. Hope this helps, good luck.
Red outlined area shows the fuse.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 243
1 Comment
Bruce, all you had to do was to add a comment to your original question:-) Anyhow that one is now deleted since it was a duplicate. Lets check on the fuse. You are pretty handy with repairs on devices that have the potential to kill you? Usually we stay away from microwaves in this section due to that potential, but I suppose a fuse should be okay.
by oldturkey03
