Repair information and guides for MacBook Pro models with 13" displays.
9739 Questions View all
Why did my laptop just up and quit working?
I was emailing someone on my Mac when suddenly it just turned off. I didn't do anything, nothing popped up and said anything; it just quit. So I thought that maybe the battery died (even though I pulled it off the charger just over an hour ago), so I plugged it back up. Now the charger is blinking orange. You can barely see the flash. Nothing will make my laptop turn on.
Score -1
Add a comment
Chosen Solution
Sounds like a battery problem. You could try Resetting the System Management Controller (SMC).
If that doesn't work the second best fix is to unplug the charger, open the machine, unplug the battery, wait a minute, reconnect the battery and the charger then try the power button again. (I would not screw the case shut until I knew I had the problem fixed)
The third thing to try (since the case is open) is a new battery.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
I got a question. I have a Dell Latitude D610, and for some reason, I'm having a whole lot of problems with it.
About 4 months ago, my brother gave it to me and said it was working fine. Not long afterwards, it started to periodically shut down, but all I had to do was pull it's plug, and reconnect, and it was back. It went completely down 7 weeks ago, with no hope of survival, I thought. Then, 3 weeks ago, I decided to mess with it one more time, and it came on.
Now, out of nowhere, it was getting hot so I shut it down to cool it off, but now, once again, it will not power up. It doesn't even get the green dot saying it's at least gerring power.
What am I not seeing, or doing, or what?
1 Comment:
Richard - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer, Question or create your own original Question.
by
Add a comment
Add your answer
Hannah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 240
