Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
822 Questions View all
Mother Board : S.O.S.
I tried an impossible repair for a customer
MacBook Pro Mid 2009
After updating interrupted, does not start. The motherboard is SOS: 3 long beeps, 3 short and 3 long
I tried everything I believe:
Reinstalling Firmware 1.7 for this model, the CD is rejected (I burned CD 3: the same)
Replacing RAM: Nothing
Replaced the battery, disconnected the battery ...
Unable to start external hard disk or DVD with install., The keyboard is not functional.
If someone in another track, I'm interested, but obviously replace the motherboard!
Firmware Pb, pb Burning CDs or DVDs
Big thank you in advance
What was being updated here: the firmware, OS or hardware?
Mac Os update only
Add a comment
Chosen Solution
From what I understand the logic board may be pooched. I know of no way to DIY correct this... a logic board repair business might be able to replace/re-flash the firmware chip... but the shade tree fix (if the reload failed) would be to replace the logic board.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
I think unfortunately you're right :(
Firmware/EFI chip changed and it works fine, Thanks
Add a comment
I don't remember seeing the OS installer do a firmware upgrade in the update process. So I'm not sure why your system bit the big one here when you were only upgrading the OS. What OS-X are you installing?
Review this Apple TN on the Beep Codes iMac (Mid 2007) and later models: About startup tones By this your Firmware is in the process of being updated. So it is likely looking for the image file on the HD or DVD you where installing the OS from. Put everything back together and as you were doing the upgrade and see if you can get the process to complete.
Score 1
Yea sometimes the firmware seems to take unusually long, and, you must let it restart (possibly more than once) on its own until it stops at the login/desktop (however you have it set up).
Mikhrych - Can you give us details on what did it. Did you just let the process complete or did you have to physically swap out the EEPROM after loading it with the firmware.
Add a comment
Add your answer
Mikhrych will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 623
