Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
How do I fix this?
my iphone 4 now has water damage. as soon as the accident happened the phone began to over heat and immediately lost all battery. now the onlytime the phone will turn on is when plugged up to a charger. then the lockscreen says ios 6. when i slide to unlockthe phone it says connect to itunes, but as soon as i unplug it from the adaptor to connect to itunes the phone turns off and will not turn on when plugged in to itunes.
Add a comment
1 Answer
Chosen Solution
amber, I suggest that you no longer try to turn it on or try to charge it. Disassemble it using this guide and properly clean it. Use this guide to clean it. It was written for a 3G but all the points are still valid for your phone as well. Always check your board for any missing, burned or otherwise damaged looking components. After that replace the battery, reassemble your phone and re-evaluate for any problems. Hope this helps, good luck.
iPhone 4 Logic Board Image
Guide
iPhone 4 Logic Board Replacement
Difficulty:
Difficult
30 minutes - 2 hours
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Score 1
Add a comment
Add your answer
amber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 38
