Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
2551 Questions View all
My LG Nitro makes noises but no image after water damage.
I can hear my phone, making noises like my alarm and even the touch screen when I hit the keyboard I hear me typing my password but absolutely no picture whatsoever is appearing and this is after I dropped my phone two days ago in a pool on mistake can the phones still be fixed and if so how?
Add a comment
1 Answer
Most Helpful Answer
There is a possibility that it can be fixed. More than likely there is corrosion on the LCD ribbon which is keeping the screen from displaying. Your going to need to clean the corrosion off before you know if the phone can be recovered or needs new parts.
You'll need:
-91% isopropyl alcohol
-Qitps
-soft bristle tooth brush( children's tooth brushes are best)
-(Optional) Compressed air, it will help with drying off components that need to be cleaned.
-And of course you'll need the tools to teardown down your phone.
Once you get your phone apart carefully look over your mother board and all the connections for your digitizer,LCD, volume ect...
If you see any corrosion take your qtip or tooth brush and clean as much as you can. Even if you dont see any corrosion on the connectors,just for good measure, clean all the connections anyway just to make sure.
When your satisfied with what you've cleaned, reassemble and check for any improvement.
Not a guarantee but its definitely worth a shot :)
Score 1
2 Comments:
I have same problem but my device is not battery removable :( what can I do!!
by
Hi @ihuda ,
What is the make and model number of your phone? Also if it has gotten wet do NOT turn it on at all and also do NOT put it in rice either as that does nothing to help.
by
Add a comment
Add your answer
mm5530 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 138
