Repair and disassembly guides for a large selection of Canon digital and film cameras.
1155 Questions View all
Service Manuals for Canon Powershot cameras?
Does anyone have a source for Service Manuals for Canon Powershot cameras? I have many working Powershot models but there is dust INSIDE the lens/ccd and I would love to take it apart to clean it. I need service guides or take-apart instructions for Powershot S100, S110, S200, SD400, SD600, SD780, SD940, SD1000, SD1100, and SD1200.
Score 2
Comments:
If you do get them all apart, I would encourage you to document the process. http://www.ifixit.com/Guide/new
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I think many people have their sources - but i see there a slightly legality issue - so the only answer i would give is: "google it"
Score 2
Add a comment
Most Helpful Answer
I don't have a service manual for you, however I've taken apart my Powershot S500 several times, including opening the lens/sensor assembly to successfully clean dust on the sensor.
I documented it in this teardown report here on ifixit. From other Powershot cameras I have seen and poked around with, the construction of others is very similar so even if you're wanting to do this with a different model, you may find my photos instructive.
I also notice there are some additional repair guides for other Canon models here on ifixit now - take a look at those also.
if you are handy with taking apart things and handling tiny screws and delicate ribbon cables, you may be able to take apart your camera without a service manual. basically just take it apart one screw at a time, save and label where the screws go, and perhaps take photos along the way (that's how my teardown photos came about). then reverse the process when done. good luck!
Score 3
Add a comment
Here's a link to the repair manuals for the Canon Powershot - Pro1, S10, S45, A70, A95, IXUS II/SD100, it's not everything you want but should give you a very good idea of how they work: http://qman.fotokala.ee/
Score 1
Add a comment
Google the following: "POWER SHOT S400 - IXUS 400.pdf" (without the quotes). You will find the parts list that gives you an idea on how to dismantle it.
I found the document here: http://www.micro-tools.net/pdf/Canon/POW...
jflarin
Add a comment
Try to find here http://service.gex-bbs.ru/canon_camera.
Add a comment
Our Canon Camera repair manual section is growing constantly. We have quite a few PowerShot models already, and we get more every few months.
Add a comment
Look service manuals here: http://www.smpcshop.com/Canon-Cameras-Se...
Add a comment
Add your answer
Rei Yoshioka will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 107
All Time: 22,999
