Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
440 Questions View all
Why wont my keyboard light work?
When I put and SSD into the Optical drive area and put back my computer. Then i installed mountain lion on it and the keyboard light does not work need this fixed.
Comments:
That did not work dan any other ideas
by
Where/What one is the small ribbon cable for the keyboard light
by
It got a little bent when I was putting back but very little
by
I replaced the keyboard and led light but is still does not work
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Try resetting the SMC Apple T/N on resetting it
Score 1
Comments:
OK then you will need to check out the small ribbon cable for the keyboard backlight did you get seated into the connector correctly? or did it get damaged in the process of working on your system.
by
Sorry - Yours has a single ribbon cableStep 17
by
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 137
