Guides and repair information for Power Macs (previously known as Power Macintosh) including G3, G4, and G5 models.
446 Questions View all
Question Closed
Power Mac G4 Won't Connect To Internet
I have an old Power Mac G4. I have turned it on and tried to connect with the internet. It says that I am connected, I open up Safari and it takes me to the Apple online page. I then proceed to attempt to try to go to any other website, but right when I select enter, Safari closes and a pop-up says "Safari has quit unexpectedly." I can also go through any branches of the Apple website, just not any other.
Add a comment
1 Answer
Chosen Solution
Open Safari again and this time go to the Safari menu and click on Reset Safari check off as much as you can then restart your system is it any better? If not you have a corrupt file somewhere. Try creating a new user account and under that user see if you are able to connect then. If not you'll need to re-install Safari or you may need to check out your HD using Disk Utility (booting up from a different disk than what your checking).
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 578
