weld antenna to the motherboard
Hello
Can you help me please, i need to weld the antenna ( the one that is put on top and which has two screws attached to the metal housing )
thanks
Hello
thanks
I believe this is the antenna mohamad is referring to. I did a little research as far as visually inspecting a motherboard that needed that part replaced and it looks like it *CAN* be replaced. As you can see in the photo there are 8 gold contacts that have to be unsolder-ed from the motherboard. These contacts are very close to other small resistors, which i assume are part of the antenna circuit. If those resistors are damaged during the antenna removal or reattachment you may render your phone a very fancy iPod touch.
If you don't have experience soldering on anything this small, find someone who does, experimenting may render your phone unfix-able or worse.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 128
1 Comment
can you add a photo of where you mean? click on images at bottom left of screen to upload
by pollytintop
