Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Salt H2O damage, multiple issues
My iPhone 4 (in otterbox defender)was exposed to salt water- splashed, not submersed. I dried it for several days in rice. Did not learn I should have flushed it with fresh water until after it was dry. The phone would not power on so I replaced the battery. I replaced the battery and the phone now works, but has several issues.
1. Power/sleep button does not work. Button depresses normally but no response.
2. WiFi cannot be turned on from settings menu.
3. Bluetooth won't connect.
4. Screen flickers rapidly, has fine black lines that travel the short width of the screen (regardless which orientation you hold it), and has a "grayed out" appearance.
All other functions appear to work. Phone takes a charge when plugged in to wall adapter. Touch screen works fine, front and rear cameras work. I can make and receive calls and check email. Head phone jack and speaker works. I couldn't see any visible corrosion when I had the case open for the battery repair.
I have searched the archives but can't determine if the above issues are interelated or independent. I can't find any reference to WiFi not turning on. I'm not sure which things to replace first and not sure if the WiFi receiver/antenna is the same as the cellular antenna or is a separate part. Should I replace things in sequence in the hopes that one item will fix multiple issues or should ? replace all at once?
Score -1
Add a comment
1 Answer
Chosen Solution
skendrot, the importance is not how long or how it got exposed, but where it got exposed. The major issue you will run into is corrosion damage. Salt Water will get your components to corrode very severely. The very first thing I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors.Look for corrosion, evaluate the pins in the connectors etc,.Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water. Use a soft brush and clean it very, very thouroughly with the sterile water. With any chance of corrosion, you will most certainly have to remove all the EMI shields as well. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Yes, you did well to replace the battery, but I would also prepare to replace the dock connector. Once it is properly cleaned, reassemble and re-evaluate. The WiFi could be an IC issue and may require a reflow. Not uncommon after water damage. Replace any parts one at a time so as to not spend unnecessary money and time and effort, as well as confusing the issue. Even with all this, there is still a chance that your phone will not work, but I definitely would give it a try. Hope this helps, good luck.
iPhone 4 Logic Board Image
Guide
iPhone 4 Logic Board Replacement
Difficulty:
Difficult
30 minutes - 2 hours
iPhone 4 Dock Connector Image
Guide
iPhone 4 Dock Connector Replacement
Difficulty:
Difficult
45 minutes - 1 hour
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Score 1
2 Comments:
Thank you! This is quite a project I've gotten myself into. The $90 life proof case is looking like a bargain now!
by
I am sure it does....:-) best of luck to you.
by
Add a comment
Add your answer
skendrot will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 201
