Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
How can I replace my digitizer when the suction cup won't stick?
I have the whole front panel assembly. I took the screws at the bottom out and attempted to pry the screen off with the suction cup. It wouldn't adhere because my screen is so shattered. I have tried tape on the screen to give the suction cup something to adhere to but it didn't work. I just need to know how to get the broken screen off so that I can install the new one.
Add a comment
Chosen Solution
use a scalpel/safety razor/very fine screw driver and insert it in the bottom left corner/along bottom edge between glass and black edge and slide the screen towards the top so you can lever your tool under the edge of the black midframe. You should then be able to get your finger nail under the edge and lift the display up.
Score 1
Add a comment
Try glue a piece of glass then use the suction cup. The front panel is trashed anyway so do whatever you can
Add a comment
Add your answer
Lori will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,188
