I have removed my screen - use it as a media center...
However.. I am unable to activate the DVI out connector as before...
The computer works perfectly, but no video is coming out of it
I can connect via Remote Desktop and use the computer
I followed every step of the iFixit guide to remove the LCD and had no problems
Any ideas?
3 Comments
Is the monitor you're connecting it to using DVI?
by rab777hp
Hi....
just to clarify....
1. the screen is broken, I decide to remove it
2. I have used this computer before, connected exactly like it is connected now to the same TV
3. I don't see my TV as a monitor when I open Displays in System Prefs.
4. When I connect my other MBP to the TV it works, no problem
5. After I removed the display, this has not worked
6. I will not be using the display, it is broken and has been removed!
by Hordur Agustsson
Well ok... I have managed to get the DVI connector to work... I did absolutely nothing
But now the fans are running at full speed... all 3 heat sensors are connected and I have reset the SMC and PRAM/NVRAM
by Hordur Agustsson
