Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1960 Questions View all
Replaced the battery but now camera shutter doesn't open.
I replaced the battery in my iphone 3gs. Everything appears to work except the camera. I can go into the app but the shutter won't open and the button to take photos does not respond. Any help for this?
Score 1
Add a comment
Chosen Solution
i'd look at your repair again and take a close look at your camera connection. It's fairly unusual to have damaged your camera-more likely it isn't connected properly, disconnect and reconnect and see what happens. It's also worth just giving the connections a little clean with a soft brush in case any debris is blocking a pin.
Score 1
Add a comment
Did all of the above several times. It is connected properly no debris on pins, shutter still wil not open.
Add a comment
Add your answer
take1risk will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 500
