Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
New battery won't boot
Installed a new battery 616-0435 it booted up fine til the lock screen the battery died so I put it on charge and is showing the charging symbol but has been like this an hour and won't turn on.. Any ideas
Score 1
Add a comment
1 Answer
Chosen Solution
sometimes it's just a battery that has sat on the shelf for a long time (these phones are years old, so the battery probably is old stock) get out your multimeter and measure the voltage coming from pins 1&4 (I think from memory) if it is less than 2.2 then you can't get it to charge. I use a 9v rectangular battery and connect 2 wires up to the battery and then the pins to give it a "boost" for about 30secs then it should charge.
Score 2
1 Comment:
failing that I'd send it back..
by
Add a comment
Add your answer
con will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 125
