Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Lost capacitor on iPhone 4 front camera's circute.
This is a photo of the exact capacitor (Element) which i lost from my logic board and causes my front camera not to work.
What type is that capacitor?
I want to fix it by myself.
Add a comment
Chosen Solution
peterrabbithsien, that is not a capacitor. It is reference designator FL21 which is a 10-OHM-200MA Filter. It is a 0201 package SMD, size is 2mmX1mmX0.7mm. So,obviously it is not going to be easy to solder. It is part of your VGA CAMERA CONNECTOR Circuit.
Hope this helps, good luck.
Score 2
Add a comment
I don't know what kind of capacitor that is but most likely a 500mu which is tiny or may be even smaller charge and if you could even find one, if you have never soldered a component on a motherboard type like this, then you may end up burning the motherboard and also the bus lines within the board then it will be toast for sure, you can try with a very low wattage iron maybe 25 to 30 watt unless this attaches another way, the picture is very hard to see but the rating for the capacitor should be right on top and the connections will be directly underneath which is the problem.............getting to them, sorry I couldn't help any more than that, good luck with that
see I told you the picture was too small I couldn't even tell it wasn't a capacitor and I really haven't had that much experience with phones, so I just learned something!
Add a comment
Add your answer
peterrabbithsien will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 1,351
