MacBook Pro models with a 15" display
8251 Questions View all
MacBook Pro 15" stuck on white screen Apple logo + Weird pattern/color
My macbook wont boot up anymore and it is stuck on the white screen. it has this weird pattern color (the apple logo looks greenish) on the white screen.
I did my research and tried several things;
-restart SMC
-restart PRAM
-Run Disk Utility (CMD + R) whenever i run the Disk Utility, the screen pattern dissapear, the grey screen looks normal I dont have those weird colors anymore. I tried to verfy my disk but it found some errors
-Safe boot (SHIFT)
-Verbose Mode (SHIFT + CMD + V)
-Fsck (CMD + S): I typed: fsck -fy in the command-line prompt a couple of times but not luck
-Reinstall Lion in Disk Utility: I can not reinstall Lion OS because it doesnt allow me to select my hard drive
I have problems with my battery allready, it heats up really fast and blocked my trackpad, I cannot click anymore.
Did my battery damaged my HD or motherboard?
Is there somebody who knows what I can do?
Score -1
Add a comment
Chosen Solution
I followed verbose mode and restarted its working fine now, thank you for the first aid
3 Comments:
what is verbose mode?
by
Given the problem I doubt this fixed it. It might have identified a bad driver loading. But even that I think is wishful thinking here. I would just try a Safe Boot to see if the problem was still present. If not then I would suspect a driver issue.
Often with odd display patterns the LCD got damaged. To verify put in an external monitor and if that is also showing a problem the graphics services is having a problem on the main logic board.
by
Add a comment
It could be that the integrated graphics is not working properly and is starting to fail. Make sure the laptop is not too hot or over heating.
Add a comment
Add your answer
Tuan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,292
